Setting the Mapping Mode of an Item
An item is published according to one of two mapping modes; sub-items or phases.
  • This mapping mode can be set per item via the mapping mode category located in the Project Management Bridge Administration scorecard/workbook, or on the sub-items configuration tab of the Project Management Bridge Administration & Configuration form.
  • If this category has not been assigned a value, then the corresponding mapping mode server default found on the defaults step of the Bridge Server Settings Wizard will determine the mapping mode for each item published to that server.
  • If the mapping mode server default has been set to Either Phases or Item (User Selectable)and the mapping mode category has been left blank, then when publishing the item for the first time, the user will be prompted to select a mapping mode.
