Stopping and Starting Primavera Portfolio Management on the server
From the console you can:
  • Stop Primavera Portfolio Management
  • Start Primavera Portfolio Management
  • Restart Primavera Portfolio Management
Stopping Primavera Portfolio Management
The "" Stop button at the top right of the console dialog box shuts down Primavera Portfolio Management for all users in your organization. The button is available only when the application is running on the server.
After you confirm your choice, users can no longer access Primavera Portfolio Management.
In scaled-out configurations, the Stop button stops components only on the server it is used on. To completely shut down Primavera Portfolio Management, you need to perform this operation on all (front-end and back-end) servers.
The "" Start button at the top right of the console dialog box enables all users in your organization who have Primavera Portfolio Management installed on their computer to access it. The button is available only when Primavera Portfolio Management is shut down on the server.
In scaled-out configurations, the Start button starts components only on the server it is used on. To completely start Primavera Portfolio Management, you need to perform this operation on all (front-end and back-end) servers.
Restarting Primavera Portfolio Management
The "" Restart button at the top right of the console dialog box shuts down Primavera Portfolio Management and immediately starts it up again. The button is available only when Primavera Portfolio Management is running on the server.
After you confirm your choice, all Primavera Portfolio Management services are shut down and then restarted.
In scaled-out configurations, the Restart button restarts components only on the server it is used on. To fully restart Primavera Portfolio Management, perform this operation on all (front-end and back-end) servers.
