Add Users and Groups For Specific Visualizations
Project/Shell Administrators can add users and groups to a project/shell from the Permissions page.
You must be the owner of the visualization or have the Manage permission enabled for visualizations in the project/shell to perform this task.
To add project/shell-level users and groups for specific visualizations:
- Sign in to Unifier with shell administration credentials.
- Go to the specific project/shell tab, and switch to Admin mode. For example, select a tab called Vision Corporation.
- In the left Navigator, select Setup, and then select Visualizations.
- In the Visualizations log (right pane), from the Action (
) menu, select Permissions for a visualization. - In the Permissions page, select Add User or Group.
- In the Add users and groups drawer:
- In the Permissions page, select the following permissions for each user and group:
- Manage Content: Select this permission to include additional visualization administrators in a project/shell. By default, they also get Modify and View permissions.
- Modify: Select this permission to add users and groups who can edit visualizations created in a project/shell. By default, they also get the View permission.
- View (Default): Select this permission to add users and groups who can only view visualizations in a project/shell.
- Select Save to add the selected users to the project/shell, and return to the Visualizations log.
