Remove Users and Groups From Specific Visualizations
Project/Shell Administrators can remove users and groups from accessing specific visualizations available in a project/shell from the Permissions page.
Contact your Company Administrator if you do not see users who should be included in a project/shell.
You must be the owner of the visualization or have the Manage permission enabled for visualizations in the specific project/shell to perform this task.
To remove shell-level users and groups from accessing specific visualizations:
  1. Sign in to Unifier with project/shell administration credentials.
  2. Go to the specific project/shell tab, and switch to Admin mode. For example, select a tab called Vision Corporation.
  3. In the left Navigator, select Setup, and then select Visualizations.
  4. For a visualization in the Visualizations log (right pane), from the Action ("") menu, select Permissions.
  5. In the Permissions page, select one or more users and groups by selecting the checkbox adjacent to the Name field of each user/group, and then select Remove.
  6. In the Remove Permissions dialog box, select Confirm to proceed with the removal process, or select Cancel if you want to discontinue removing users and groups.
  7. Select Save, and return to the Visualizations log.
