Configure Custom Data Views for Navigation from Visualizations
When custom data sources created from data views are used to create visualizations, data view authors need to be able to access the underlying data source and trace it to the relevant Unifier module such as a cash flow, cost sheet, or business process (BP) upon selecting a content item such as a chart or a pivot grid in a visualization.
Prerequisites
- You have access to create or edit the data view.
- The data view supplies data to a visualization or dashboard.
Procedure
To support navigation to the relevant Unifier module, administrators must define additional navigation context in the custom data source definition as follows:
Result:
The system uses this context with the selected field value, such as a record number or title, to determine the correct navigation target.
