View and Export the Data Source Usage Log
The Usage Log is available for data sources with Used status only. The log displays how the data source is being used by displaying a list of content items that use each data source. Company Administrators can view and export the usage log of each data source.
You must have Configure or View permissions for Data Sources in the Company Workspace to perform this task.
To view and export the usage log of a data source:
- Sign in to Unifier with company administration credentials.
- Go to the Company Workspace tab, and switch to Admin mode.
- In the left Navigator, select Visualizations, and then select Data Sources.
- In the Data Source log (right pane), in the Usage column, select Used for the data source.
- In the Usage Log drawer, view the following information:
- Content Name: The name of the content item using the data source.
- View Type: The type of content item created such as a Bar chart, Pie chart, and so on.
- To download the log as a Microsoft Excel spreadsheet (.xlsx), select Export (
). You must have Configure permissions.
