View and Export the Data Source Audit Log
The audit log is a chronological list of actions performed by all users with access to the data source. Company Administrators can view and export the audit log.
You must have Configure permission for visualization data sources to complete this task.
To view and export the audit log of a data source:
- Sign in to Unifier with company administration credentials.
- Go to the Company Workspace tab, and switch to Admin mode.
- In the left Navigator, select Visualizations, and then select Data Sources.
- In the Data Sources log (right pane), select Audit Log for a data source.
- In the Audit Log drawer, view the following information:
- Modified: Date and time each change was made in the data source. Date and time format is based on the user's preferences.
- Action: Type of change made to the data source. Actions include Created, Published, Updated, and more.
- Modified By: Name of the user who made the change in the data source.
- To download the audit log as a Microsoft Excel spreadsheet (.xlsx), select Export (
