Restore Data Sources to the Last Published Version
You can revert to a previously published version of a data source. This action can only be performed on data sources whose current status is Published and edited.
You must have Configure permission for visualization data sources to complete this task.
To revert to a previous published version of a data source:
  1. Sign in to Unifier with company administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select Visualizations, and then select Data Sources.
  4. In the Data Sources log (right pane):
    1. Select the checkbox for a data source whose status is Published and edited.
    2. From the More Actions menu, select Restore to Last Published.
    3. In the confirmation dialog box, select Yes; otherwise, select No to discontinue this task.
      Verify the changes have been reverted in the data source.
