Delete Data Sources
You can delete draft and published data sources only if they are not used for data visualizations. Their Usage status should indicate Not Used in the Data Sources log.
You must have Configure permission for visualization data sources to complete this task.
To delete one or more data sources for data visualizations:
  1. Sign in to Unifier with company administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select Visualizations, and then select Data Sources.
  4. In the Data Sources log (right pane), select the checkbox corresponding to one or more data source whose Usage indicates Not Used.
  5. From the More Actions menu, select Delete.
  6. In the Delete Items(s) confirmation dialog box, select any of the following options:
    • Select Delete to delete the data source.
    • Select Cancel to discontinue deleting the data source.
      Deleted data sources cannot be recovered.
