Update AI-Generated Content Recommendations (Cloud Only)
Video: Create AI-Generated Content Recommendations in Admin Mode
When the Content Recommendations feature is enabled, you can review and select content to add to the Content Library after publishing a data source.
You can update content selections both immediately after publishing a data source and at any time for existing published data sources.
You must have Configure permission for visualization data sources and content to complete this task.
To view and select content for inclusion in the library:
- Go to the Company Workspace tab, and switch to Admin mode.
- In the left Navigator, select Visualizations, and then select Data Sources.
- In the Data Sources log, select the checkbox for the one Published data source you want to add content from, and then select Recommend Content.
You can only select one Published data source at a time. - On the Content Recommendation page, select the applicable project from Preview Project.
You can perform any of the following actions:
- To view the data for the applicable project, select Preview Data (
- To maximize the view of a visualization, select it.
- To view additional information about a visualization, hover over the Information (
) icon or the Tooltip (
) icon.
- To view more content recommendations, select Generate More Recommendations at the bottom of the page.
- Select the check box for the items that you want to add to the Content Library.
- When you have finished, select Save to Content in the upper-right corner.
This summary was prepared by generative AI. Carefully review and verify it against trusted sources, as it may include out-of-date, inaccurate, or incomplete information.
