Create Data Sources
Company administrators are the first group of users who determine the data sources that can be made available to users for creating visualizations. You must have Configure permission to create data sources for visualizations.
To create data sources for data visualizations:
  1. Sign into Unifier with Administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select Visualizations, and then select Data Sources.
  4. In the Data Sources log (right pane), select Create.
  5. Complete the Data Source Creation Guided Process.
    • Required fields are indicated in the user interface.
    • If a data source is removed from a BP design or data view, update the data source before you create, view, or update the content based on that data source.
