Keyboard Navigation
You can use your computer keyboard to navigate through the application. Use the following keyboard shortcuts to access frequently used or important functionality. Note that keyboard shortcuts may change depending on your selected browser, and disabled buttons/fields are skipped.
Guided Process Overview Page
| Action | Windows Shortcut Key | Mac Shortcut Key |
| Move through elements on the page | Press Tab | Press Tab |
| Select a current focus element | Press Enter | Press Enter |
Guided Process Step Page
| Action | Windows Shortcut Key | Mac Shortcut |
| Move through elements on the page | Tab | Tab |
| Select a current focus element on the Step page | Enter | Enter |
| Move the focus between the elements in the footer toolbar (left) | ||
| Move the focus between the elements in the footer toolbar (right) | ||
| Move up | ||
| Move down | |
