Create or Edit Pivot Grids for Visualizations in Projects/Shells
To create or edit Pivot grids for visualizations in a project/shell (Admin mode):
- Sign in to Unifier with project/shell administration credentials.
- Select the specific project/shell tab, and switch to Admin mode.For example, select a tab called Vision Corporation.
- In the left Navigator, select Setup, and then select Visualizations.
- In the Visualizations log (right pane), perform one of the following actions:
- Select Create to add a new visualization in the project/shell. Then on the Create page, do the following to preview the data before creating the item:
- From the Data Source list, select the data source to use for creating the content item. The list shows published content in the alphabetical order.
- From the Preview Project list, select an active project/shell and then select Preview Data.
or
- Select a visualization in the log and select Edit. Then on the Edit page, select Edit
for a content item in the visualization layout.
- On the Create or Edit page, specify or update the following information:
- From the View Type list, select Pivot Grid.
- In the Name field, enter a name for the Pivot grid.
- Optional: In the Description field, enter a short description about the Pivot grid.
- From the Value list, select a data element from the data source selected above. Displays Count by default.
For the selected data element in the Value list, select any of the following measures:
- Average: The mean of all values of the selected data element.
- Count: (Default) The total number of rows of the selected data element.
- Max: For numeric fields, displays the highest value. For date fields, displays the maximum date.
- Median: The central value among all values of the selected data element.
- Min: For numeric fields, displays the lowest value of the selected data element. For date fields, displays the minimum date.
- Sum: Sum of all values of the selected data element.
- From the Columns list, select a data element to create columns for the Pivot grid.To specify a sort order, select
. Choices include Ascending, Descending, and None. - Optional: To include additional column tiers in the Pivot grid, click Add Columns.
- From the Rows list, select a data element to create rows for the Pivot grid.To specify a sort order, select
. Choices include Ascending, Descending, and None. - Optional: Click Add Rows to include additional row tiers in the Pivot grid.
- Optional: In the Column Totals field, select whether to show or hide the column totals in the grid.
- Optional: In the Row Totals field, select whether to show or hide the row totals in the grid.
- To visually highlight specific fields, see Configure and Manage Conditional Formatting of Tables and Pivot Grids.
- Make changes as needed to refine the above selections.
- After making all changes, perform any of the following actions:
- If you created a Pivot grid, select Create, and return to the Edit page.
- To confirm all the changes made to the edited grid, select Update, and return to the Edit page.
- On the Edit page, select Save to update the visualization with any created or edited content.
