Creating Shell Templates
You can create shell templates manually or by copying an existing template or shell. As noted earlier, shell template names are not enforced as unique. If multiple shell templates have the same name, synchronization or integration processes can fail because the application cannot identify the correct template.
If a gateway synchronization error such as Query returns multiple results: null occurs, change the shell template name to a unique value, and then retry synchronization.
