Delete Content
From the Content log, you can delete multiple content items that are currently in Published or Draft statuses if their Usage status is Unused. An error message displays if you choose to delete a content item in Used status.
You must have Configure permission for visualization content to complete this task.
To delete unused content items:
  1. Sign in to Unifier with company administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select Visualizations, and then select Content.
  4. In the Content log (right pane), select the checkbox for one or more unused content items in Draft or Published statuses, and then select Delete.
  5. In the Delete Items dialog box, select Delete to reconfirm.
