View and Export the Audit Log of Visualization Contents
The Audit Log displays a chronological list of actions performed in a visualization by all users with access to the Content log in the Company Workspace (Admin). Company Administrators can view and export the audit log.
You must have Configure or View permissions to check the audit log of content for visualizations in the Company Workspace to perform this task.
To view and export the audit log of a content item:
- Sign in to Unifier with company administration credentials.
- Go to the Company Workspace tab, and switch to Admin mode.
- In the left Navigator, select Visualizations, and then select Content.
- In the Content log (right pane), select the Audit Log (
) of a visualization.- Modified: Date and time each change was made in the data source. The date and time format is based on the user's preferences.
- Action: Type of change made to the content, such as, Created, Draft, Published, and Duplicate.
- Modified By: Name of the user who made the change in the data source.
- If you have Configure permission, select Export (
) to download the audit log as an Excel spreadsheet (.xlsx).
