View and Export the Visualizations Usage Log
The Usage Log is available for content items in Used status only. The log displays information on where the content item has been used in visualizations. Company Administrators can view and export the usage log for each content item.
You must Configure or View permissions for visualization content in the Company Workspace to perform this task.
To view or export the usage log of a content item:
  1. Sign in to Unifier with company administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select Visualizations, and then select Content.
  4. In the Content log (right pane), select Used for a content Name.
  5. In the Usage Log drawer, view the following information:
    • Visualization: Name of the visualization using the content item.
    • State: The current state of the visualization as Synced or
  6. If you have Configure permission, select Export ("") to download the log as a Microsoft Excel spreadsheet (.xlsx).
