Duplicate Data Sources
You must have Configure permission for visualization data sources to complete this task.
To duplicate data sources for visualizations:
  1. Sign in to Unifier with company administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select Visualizations, and then select Data Sources.
  4. In the Data Sources log (right pane), select the checkbox corresponding to one or more data sources, and then select Duplicate.
A duplicate of each data source is created with "Copy1" suffixed to the name of the data source.
