Modify Data Sources
To modify data sources for data visualizations:
  1. Sign in to Unifier with company administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select Visualizations, and then select Data Sources.
  4. In the Name column of the Data Sources log (right pane), select a data source.
  5. Navigate through the guided process and update the data source as required.
The status of data source is updated to reflect the current status as either Draft, Published, or Published and edited.
