Enable Permissions to Administer or View Visualizations Content in the Company Workspace
To administer content, Company Administrators must be able to access the Visualizations node in the left Navigator from the Company Workspace tab in the Admin mode. Completing this task displays the Visualizations sub-node under the Setup node in the left Navigator. As a Company Administrator, you can set up this permission for yourself and for other users and groups you select as additional company administrators.
To set permissions to administer or view content from the Visualizations node in the left Navigator of the Company Workspace tab:
  1. Sign in to Unifier with company administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select User Administration, and then select Access Control.
  4. In the Access Control log (right pane), expand Administration Mode Access, select the Visualizations node, and then select the Content sub-node.
  5. In the Permissions Settings for: Data Sources dialog box, select Add.
    1. In the Select User/Groups block (upper block), select Add Users/Group.
      1. In the User/Group Picker window, select yourself and any other users and groups you want to add as Content Administrators or Content Viewers.
      2. Select Add, and then select OK.
    2. In the Permission Settings block (lower block), select the following permissions for each user/group selected in the upper block (step 5a):
      • Configure: Select this permission to administer content from the Visualizations node in left Navigator in the Admin mode.
      • View: Select this permission to view content from the Visualizations node in left Navigator in the Admin mode.
    3. Select OK.
  6. Select OK.
