Enable Permissions to View Visualization Content in the User Mode
Company Administrators can set up permissions for users and groups to view visualization content in the User mode.
To set permissions that will enable view access to the Visualizations node in the left Navigator in the User mode:
  1. Sign in to Unifier with company administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select User Administration, and then select Access Control.
  4. In the Access Control log (right pane), expand User Mode Access, and then select the Visualizations node.
  5. In the Permissions Settings for: Visualizations dialog box, select Add.
    1. In the Select User/Groups block (upper block), select Add Users/Group.
      1. In the User/Group Picker window, select users and groups to give view-only permission for visualization content.
      2. Select Add, and then select OK.
    2. In the Permission Settings block (lower block), select the View permission for each user and group selected in the upper block (step 5a), and then select OK.
  6. Select OK.
