Enable Permission to Administer Visualizations in Projects/Shells
To administer visualizations in a project/shell, Project/Shell Administrators must be able to access the Visualizations node in the left Navigator. Completing this task displays the Visualizations sub-node under the Setup node in the left Navigator of the project/shell. As a Project/Shell Administrator, you can set up this permission for yourself as well as for any other users and groups you select as additional project/shell administrators.
To set the permission that will allow you to administer and give access to the Visualizations node in the left Navigator of a project/shell:
- Sign in to Unifier with project/shell administration credentials.
- Go to the project/shell tab, and switch to Admin mode. For example, select a tab called Vision Corporation.
- In the left Navigator, select Access Control.
- In the right pane, under the Administration Mode Access node, select Setup and then select Visualizations.
- In the Permissions Settings for: Visualizations dialog box, select Add.
