Enable View Permission For Visualizations in Projects/Shells
Apart from setting up additional administrators for a project/shell, Project/Shell Administrators can also set up users and groups who can only view visualizations created in a project/shell. Completing this task displays the Visualizations node in the left Navigator of the project/shell for your users and groups when they sign in to the project/shell in the User mode.
To set the permission that will allow your users and groups to access the Visualizations node in the left Navigator of a project/shell in User mode:
- Sign in to Unifier with project/shell administration credentials.
- Go to the project/shell tab, and switch to Admin mode. For example, select a tab called Vision Corporation.
- In the left Navigator, select Access Control.
- In the right pane, under the User Mode Access node, select Visualizations.
- In the Permissions Settings for: Visualizations dialog box, select Add.
