Publish Content
From the Content log, you can publish content items, such as a Bar chart, a KPI card, or a KPI Scoreboard, that are currently in Draft status. When you publish content, your users can now use this content to create visualization pages in the corresponding data source.
You must have Configure permission for visualization content to complete this task.
To publish content items for visualizations:
  1. Sign in to Unifier with company administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select Visualizations, and then select Content.
  4. Use any of the following methods to publish:
    • Publish multiple content items simultaneously from the Content log (right pane). In the Content log (right pane), select the checkbox for multiple content items in Draft status, and then select Publish.
    • Update and then publish an individual content item from the Content log (right pane):
      1. In the Content log (right pane), select to open a content item in Draft status.
      2. Make changes as required to the content item.
      3. From the Actions menu, select Update Draft.
      4. To publish the updated content item, from the Actions menu, select Restore to Published.
