Duplicate Content
From the Content log, you can efficiently create content by duplicating multiple content items and modifying each as needed. For example, select and create duplicates of a Bar chart, KPI card, and KPI scoreboard, and then modify each accordingly.
You must have Configure permission for visualization content to complete this task.
To duplicate content items for visualizations:
  1. Sign in to Unifier with company administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select Visualizations, and then select Content.
  4. In the Content log (right pane), select the checkbox for one or more content items such as a KPI card or a Bar chart, and then select Duplicate.
    The duplicate item is created with a Draft status wherein the name of the duplicate is suffixed with "Copy1". For example, KPI Card Copy 1.
