Update All Shell Templates with Visualizations
From the Company Workspace tab, you can replicate visualizations created in a specific project/shell template across all project/shell templates.
To copy visualizations from a project/shell template into all project/shell templates:
- Sign in to Unifier with company administration credentials.
- Go to the Company Workspace tab, and switch to Admin mode.
- In the left Navigator, select Templates, select Shells, and then select Projects.
- In the Project Templates log (right pane), select a project template.
- From the gear menu (
), select Open to open a project template. - Under the opened project/shell template node in the left Navigator, select Setup and then select Visualizations.
- In the Visualizations log (right pane), select the checkbox for one or more visualizations that you want to replicate.
- From the Update menu, select All Shell Templates.
- In the Update All Shell Templates dialog box, select Update to reconfirm.
Review the visualizations in the updated project/shell templates.
You can select Cancel in any step to discontinue this task.
