Update Specific Projects/Shells with Visualizations From Project/Shell Template
From the Company Workspace tab, you can selectively replicate visualizations across one or more individual projects/shells.
To copy visualizations from a project/shell template into one or more projects/shells:
  1. Sign in to Unifier with company administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select Templates, select Shells, and then select Projects.
  4. In the Project Templates log (right pane), select a project template.
  5. From the gear menu (""), select Open to open a project template.
  6. Under the opened project/shell template node in the left Navigator, select Setup and then select Visualizations.
  7. In the Visualizations log (right pane), select the checkbox for one or more visualizations that you want to replicate.
  8. From the Update menu, select Shells.
  9. In the Update Shells drawer, select the checkbox for one or more projects/shells that the selected visualizations (step 7) will be copied into, and select Update.
  10. In the Update Shells dialog box, select Update to reconfirm.
Review the visualizations in the respective projects/shells.
You can select Cancel in any step to discontinue this task.
