Update All Projects/Shells with Visualizations From a Project/Shell Template
From the Company Workspace tab, you can replicate visualizations across all projects/shells.
To copy visualizations from a project/shell template into all projects/shells:
  1. Sign in to Unifier with company administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select Templates, select Shells, and then select Projects.
  4. In the Project Templates log (right pane), select a project template.
  5. From the gear menu (""), select Open to open a project template.
  6. Under the opened project/shell template node in the left Navigator, select Setup and then select Visualizations.
  7. In the Visualizations log (right pane), select the checkbox for one or more visualizations that you want to replicate.
  8. From the Update menu, select All Shells.
  9. In the Update All Shells dialog box, select Update to reconfirm.
Review the visualizations in the updated projects/shells.
You can select Cancel in any step to discontinue this task.
