Update Selected Project/Shell Templates with Visualizations
From the Company Workspace tab, you can selectively replicate visualizations across one or more project/shell templates.
To copy visualizations from a project/shell template into one or more project/shell templates:
- Sign in to Unifier with company administration credentials.
- Go to the Company Workspace tab, and switch to Admin mode.
- In the left Navigator, select Templates, select Shells, and then select Projects.
- In the Project Templates log (right pane), select a project template.
- From the gear menu (
), select Open to open a project template. - Under the opened project/shell template node in the left Navigator, select Setup and then select Visualizations.
- In the Visualizations log (right pane), select the checkbox for one or more visualizations that you want to replicate.
- From the Update menu, select Shell Templates.
- In the Update Shell Templates drawer, select the checkbox for one or more project/shell templates that the selected visualizations (step 7) will be copied into, and select Update.
- In the Update Shell Templates dialog box, select Update to reconfirm.
Review the visualizations in the updated project/shell templates.
You can select Cancel in any step to discontinue this task.
