Update the History Log Across Shell Templates
After populating projects/shells with visualizations, it is a good practice to update the job history of the updated projects/shells to maintain the chronology of actions performed in each project/template.
To update the history log across one or more projects/shells:
  1. Sign in to Unifier with company administration credentials.
  2. Go to the Company Workspace tab, and switch to Admin mode.
  3. In the left Navigator, select Templates, select Shells, and then select Projects.
  4. In the Project Templates log (right pane), select a project template.
  5. From the gear menu (""), select Open to open a project template.
  6. Under the opened project/shell template node in the left Navigator, select Setup and then select Visualizations.
  7. In the Visualizations log (right pane), from the Update menu, select History.
  8. In the History drawer, perform any of the following actions:
    • Select the checkbox for each project/shell whose history is to be updated, and select Refresh.
    • Select Cancel Request to cancel a job request that has not yet started. You cannot cancel a job request that is in progress or revert if the job request has been completed.
Review the history log in the updated projects/shells.
You can select Cancel in any step to discontinue this task.
