View and Export the Visualizations Audit Log From Projects/Shells
Project or Shell Administrators can view or download the audit log of a visualizaition.
The Audit Log displays a chronological list of actions performed on visualizations by all users/groups in the Visualizations log of a project/shell.
You must have Modify or Manage Content permission enabled for visualizations in the specific project/shell to perform this task.
Procedure
- Sign in to Unifier with project/shell administration credentials.
- Go to the specific project/shell tab, and switch to Admin mode. For example, select a tab called Vision Corporation.
- In the left Navigator, select Setup, and then select Visualizations.
- In the Visualizations log (right pane), from the Action (
) menu, select Audit Log.- Modified: Date and time each change was made in the data source. The date and time format is based on the user's preferences.
- Action: Type of change made to visualizations, such as, Created, Added, Removed, Updated, Duplicate, and so on.
- Modified By: Name of the user who made the change in the data source.
- To view the displayed column information in the ascending or descending order, select Sort By.
- To download the audit log as a Microsoft Excel spreadsheet, select Export (
