Set a Visualization as the Default Standard Project or Shell Dashboard
You can select a visualization to display by default in a Standard Project or Shell Dashboard.
Prerequisite
You have Modify or Manage Content permission for visualizations in the project or shell.
Procedure
  1. Sign in to Unifier with project or shell administration credentials.
  2. Go to the specific project or shell tab, and switch to Admin mode.
    For example, select a tab called Vision Corporation.
  3. In the left Navigator, select Setup, and then select Visualizations.
  4. In the Visualizations log (right pane), from the Action "" menu, select Set As Default Dashboard.
  5. In the Replace existing default? dialog box, select Yes to reconfirm your choice.
The visualization appears by default in the Standard Project or Shell dashboard.
