Deleting an Oracle Integration Connection
You can delete Oracle Integration configurations only if they are not in use.
To permanently delete an Oracle Integration connection:
  1. Go to the Company Workspace tab, and switch to Admin mode.
  2. In the left Navigator, select Integrations, and select Oracle Integration Cloud.
  3. In the left pane of the Integrations tab, select a module. For example, Business Processes.
  4. In the right pane, select a row to delete that integration. For example, select an integration named Contracts.
  5. In the Action field, select Delete "".
