Editing an Oracle Integration Endpoint Connection
You can modify the endpoint connection details as needed even when an Oracle Integration endpoint is in use
To edit an Oracle Integration endpoint connection:
- Go to the Company Workspace tab, and switch to Admin mode.
- In the left Navigator, select Integrations, and select Oracle Integration Cloud.
- In the left pane of the Integrations tab, select a module. For example, select Business Processes.
- In the right pane, select a row to edit that integration. For example, select an integration named Contracts.
- In the Action field, select Edit
. - Make changes to any of the following fields: OIC Name, API Path, or Activate.
- In the Action field, perform any of the following actions:
Select Save
to update the endpoint information.
- Select Cancel x to discontinue editing the endpoint information.
Select Save
