Disabling Oracle Integration Connection
To disable the Oracle Integration connection:
  1. Go to the Company Workspace tab, and switch to Admin mode.
  2. In the left Navigator, select Integrations, and select Oracle Integration Cloud.
  3. In the Connect tab, set Enable Integration to No.
