Enabling Oracle Integration Connection
After initial setup, you can connect with Oracle Integration as-needed, on demand.
To enable the Oracle Integration connection:
- Go to the Company Workspace tab, and switch to Admin mode.
- In the left Navigator, select Integrations, and then select Oracle Integration Cloud.
- In the Integrations tab, specify or recheck the endpoints from Oracle Integration.
- In the Connect tab:
- Enter or recheck the connection parameters.
- Select Save & Generate Access Token.
This generates a token and sets the Enable Integration field to Yes on connecting successfully. Otherwise, recheck your Oracle Integration configuration details.
- Proceed to work on your business processes (BPs).
