Project/Shell Business Flow
When defining a Business Flow in Unifier Provider (Project/Shell), the destination application parameters for Unifier Provider, Project object, enable you to define the location (Location) and template (Template) as parameters. These attributes are specific to Unifier and eliminate the need for the source application to send values for fields.
If the source application sends value for either of the parameters mentioned below via data mapping and you define the parameter value in the business flow, the value sent by way of mapping takes precedence.
The following parameters are required for successful project creation in Unifier.
Oracle recommends that you set these parameters as "Required" in the Business Flow definition.
Object Value Description
Project Location
This is a Text field. You must enter only one location.
Example
All Regions > Sites > Properties
If you enter multiple locations, Unifier Provider will not be able to resolve the location and project creation will fail.
Use this parameter to identify the location (Location): Where the Unifier project must be created.
You can also add the location as "Shell Attribute" (uuu_location) when defining the "Project" object filters.
If you define the location parameter as a shell attribute (uuu_location = <xyz>), and use the available drop-down field (Location) for the Project object, project creation will fail.
If you add a filter row by selecting the fields as Shell Attribute Form and provide a value of the Shell Location, for Project object, project creation will fail.
Project Template Number
This is a Text field. You must enter only one number.
If you enter multiple numbers, Unifier Provider will not be able to resolve the template and project creation will fail.
Use this parameter to identify the templates which must be used to create the new Project.
