Project/Shell Data Dictionary
The following table describes the Data Dictionary for Unifier Provider (Project/Shell):
Attribute Name Description
Status
To capture the status of projects.
Since projects must have one of following statuses, the user must define the data value mapping XML to map status of source project and to a project status value.
  • Active
  • On-Hold
  • View-Only
  • Inactive
Location
The location of the destination Unifier Project.
Example
All Regions, which includes Sites, which includes Properties
Template
The "Number" of the template which must be used to create a new project.
  • Shell Template Numbers are enforced to be unique across all shell template types.
  • The system determines the "Type" of the shell that must be created, using the template number.
