Configuring CBS Shell Types with Oracle Integration for P6 System Activity Sheets
Company Administrators and Shell Administrators can configure Oracle Integration as the default integration engine for specific projects in single shells of CBS shell type. This ensures all system actions and integrations consistently follow the selected engine, supporting Oracle’s transition to Oracle Integration and removing ambiguity from integration paths.
Benefits
- Clear Engine Selection: Administrators can explicitly select the integration engine for each project, preventing misconfiguration and ensuring systems route integration requests to the correct platform.
- Simplified Management: Configuration and migration steps are visible and straightforward, reducing ambiguity over which integration path is active.
- Confirmation on Migration: Built-in confirmation dialog boxes to switch engines help avoid accidental data or configuration loss.
- Consistent Schema: No changes to field names or data types when switching engines means existing reports and workflows.
- Enhanced Auditing: Each integration run is recorded with engine details, status, and user activity, supporting efficient troubleshooting and compliance tracking.
- Unambiguous routing ensures all system activity for the project uses only the chosen integration engine.
- No disruption to existing reports or mobile applications.
Limitations
- Only one engine can be selected per project. Fallback is not supported.
- If Oracle Integration prerequisites are not met, action is blocked until resolved.
- Prior Primavera Gateway configuration is deleted when switching to Oracle Integration.
Prerequisites
- Oracle Integration is enabled at the company level as the integration engine as outlined in the Initial Oracle Integration Setup.
- You have the required permissions to set up P6 schedule integrations as an administrator.
- Existing Primavera Gateway integrations are removed upon switching to Oracle Integration. Be aware of business and technical impacts.
Procedure
To set up Oracle Integration as the default integration engine of choice in single shells of CBS shell type for P6 System Activity Sheets:
Alternative Method
You can also configure shells to use Oracle Integration as the default engine using the Update Shell REST endpoint.
