4 Activate and Run the Recipe
After configuring all of the connections, activate and run the integration.
Activate the Integration
Activating at the project level activates all the integrations in the project in a single step. In this case, there is only one integration, so activating at the project level is the same as activating at the integration level.
Run the Integration
This recipe delivers a single integration:
- Scheduled Unifier to Fusion ERP Projects Sync
To run the integration:
Monitor the Integration
You can monitor instances and errors directly within the project workspace and also from the global observability pages.
