Configure Primavera Unifier
To configure Primavera Unifier for this recipe, complete the initial setup outlined below:
Create an integration user
You will use this account when configuring the Primavera Unifier connections delivered in this recipe.
For details, see Creating Integration Users.
Grant required permissions
Ensure the integration user can access the modules used by the recipe (Project Shell areas).
To grant these permissions in Primavera Unifier, go to Company Workspace, switch to Admin mode, then select .
Configure custom data view
To get a list of projects with necessary data, create a custom data view in Primavera Unifier:
- Go to Company Workspace, switch to Admin mode, then select .
- Click New.
Fill in the following required fields along with the SQL definition provided below:
- Prefix: Unifier_
- Name: project_erp_report
- Label: Projects to ERP report
- Description: Used in Project UDR for Unifier - Fusion ERP integration
SQL Definition:
SELECT DISTINCT x.* FROM ( SELECT p.ue_prj_ProjNameSSN AS project_name, p.ue_prj_ProjNumSSN AS project_number, CASE WHEN p.ue_prj_TemplateNameTB128 IS NULL OR p.ue_prj_TemplateNameTB128 = '' THEN 'UNDEFINED_TEMPL' ELSE p.ue_prj_TemplateNameTB128 END AS shell_template, p.pid AS project_id_from_project, xorg.pid AS organization, usi.companyid AS legal_entity, p.description AS description, p.ue_prj_ProjManagerPKUS AS project_manager, p.k__ue_prj_ProjManagerPKUS AS project_manager_id, TO_CHAR( NVL( p.ue_prj_ProjActStartDateDP, NVL( p.ue_prj_ProjPlnStartDateDP, NVL( p.ue_prj_ProjPlnStartDateDO, p.uuu_project_start_date ) ) ), 'YYYY/MM/DD' ) AS project_start_date, TO_CHAR( NVL(p.ue_prj_ProjActEndDateDP, p.ue_prj_ProjEndDateDO), 'YYYY/MM/DD' ) AS project_end_date, -- 0: Inactive, 1: Active, 2: On-Hold, 3: View-Only CASE p.uuu_shell_status WHEN 0 THEN 'Inactive' WHEN 1 THEN 'Active' WHEN 2 THEN 'On-Hold' WHEN 3 THEN 'View-Only' END AS project_shell_status_details, p.uuu_shell_status AS project_status, p.ue_prj_ProjTypeIPD AS project_type_spd, usi.last_modified_date AS last_shell_update, 0 AS new_project, usi.createdate AS create_date FROM unifier_us_xprj_view p LEFT JOIN unifier_shell_link_view uslv ON uslv.child_id = p.pid LEFT JOIN unifier_shell_info_view usi ON usi.pid = p.pid LEFT JOIN unifier_us_xprj_view p1 ON p1.pid = uslv.child_id LEFT JOIN unifier_us_xorg xorg ON xorg.pid = usi.rootid AND xorg.uuu_shell_status = 1 WHERE uslv.child_id_model = 'us_xprj' AND usi.istemplate = 0 ORDER BY uslv.child_id ) x;
- Select the newly created data view, click Status and select Published.
For details, see Creating a Shell.
Configure a user defined report (UDR)
In Primavera Unifier, prepare a user defined report (UDR) which will get the changed project data for the active and on hold projects. The UDR will accept a last run date (with time) parameter from Oracle Integration. The UDR will bring all the changed projects from last run date to current date. For the first run, the last run date will be passed as blank. This will synchronize all the projects from Primavera Unifier into Oracle Fusion Cloud ERP.
- Go to .
- Click Create and select From System Data Source.
- On the General tab, enter the following:
- Report Name: OIC_Project_Integration_UDR_DW
- Report Title: OIC_Project_Integration_UDR_DW
- Description: User defined report (UDR) to retrieve the changed project data since specified date-time.
- Data Type: Project ERP report
- Report Type: Tabular
- Access Type: System
- Enable for Integration: True
- Accessible: Not Selected
- Default Time Zone: (UTC) Coordinated Universal Time
- Under Columns, select:
- _project_erp_report / PROJECT_NAME → PROJECT_NAME
- _project_erp_report / PROJECT_NUMBER → PROJECT_NUMBER
- _project_erp_report / SHELL_TEMPLATE → SHELL_TEMPLATE
- _project_erp_report / PROJECT_ID_FROM_PROJECT → PROJECT_ID_FROM_PROJECT
- _project_erp_report / ORGANIZATION → ORGANIZATION
- _project_erp_report / LEGAL_ENTITY → LEGAL_ENTITY
- _project_erp_report / DESCRIPTION → DESCRIPTION
- _project_erp_report / PROJECT_MANAGER → PROJECT_MANAGER
- _project_erp_report / PROJECT_MANAGER_ID → PROJECT_MANAGER_ID
- _project_erp_report / PROJECT_START_DATE → PROJECT_START_DATE
- _project_erp_report / PROJECT_END_DATE → PROJECT_END_DATE
- _project_erp_report / PROJECT_STATUS → PROJECT_STATUS
- _project_erp_report / PROJECT_SHELL_STATUS_DETAILS → PROJECT_SHELL_STATUS_DETAILS
- _project_erp_report / PROJECT_TYPE_SPD → PROJECT_TYPE_SPD
- _project_erp_report / LAST_SHELL_UPDATE → LAST_SHELL_UPDATE
- _project_erp_report / CREATE_DATE → CREATE_DATE
- _project_erp_report / NEW_PROJECT → NEW_PROJECT
- Under Query, select:
- Data Element: _project_erp_report / LAST_SHELL_UPDATE , Label: LastUpdateDate, Condition : greater than or equals
- Data Element: _project_erp_report / PROJECT_SHELL_STATUS_DETAILS , Label:PROJECT_SHELL_STATUS_DETAILS, Condition : contains, Values: 'Active','On-Hold'
- Under Layout, select:
- Page Orientation: Landscape
- Paper Size: Unlimited
