Configure Oracle Fusion Cloud ERP
To configure Oracle ERP for this recipe, complete the initial setup outlined below:
Create an integration user (recommended)
You can create a new or use an existing integration user account in Oracle ERP to connect with Oracle Integration and manage integrations. Make sure necessary user roles and permissions are set up properly.
Project source application configuration
  1. Navigate to Setup and Maintenance.
  2. Select Setup: Project Financial Management, and then Functional Area, and then Project Foundation.
  3. Select Show "All Tasks", and then Manage Source Applications.
  4. Select the Standard Lookup Type: PJF_PM_PRODUCT_CODE.
  5. Click Add to add a new Lookup Code for ORAC_UNIFIER:
    • Lookup Code: ORAC_UNIFIER
    • Enabled: Yes
    • Start Date: 1/1/51
    • Meaning: Primavera Unifier
    • Description: Project data is imported or updated from Primavera Unifier
