4 Activate and Run the Integrations
After configuring the connections, you can activate and run the integrations.
The integrations that you will activate and run depend on your workflow (whether you are migrating a single or multiple projects) and the direction of the migration (whether you are migrating from Primavera P6 EPPM or Oracle Primavera Cloud).
