3 Install and Configure the Recipe
On your Oracle Integration instance, install the recipe to deploy and configure the integration and associated resources.
Configure the Oracle Primavera Cloud Connections
After installing this recipe, you need to configure the delivered connections.
This recipe delivers the following connections:
- Oracle Primavera Cloud Connection - This is the source connection.
- Oracle Primavera Cloud Target Connection - This is the target connection.
Both connections use the REST Adapter to connect to Oracle Primavera Cloud.
Perform the following configuration steps for both connections listed above.
Update Integration Properties
Activate the integration and then update the integration property values to specify the source project ID, source and target workspace IDs, and the email address of the integration user account.
- In the Integrations section, find the Migrate Primavera Cloud Project Data integration.
- Activate the integration.
- Click Actions
next to the integration, then select
Activate. - In the Activate integration panel, select the appropriate tracing level, then click Activate.
- Click Actions
- Update the integration property values.
You get a confirmation message that the integration properties have been updated successfully.
