2 Before You Install the Recipe
You must perform the following configuaration tasks on your Oracle Primavera Cloud environment to successfully connect to it from Oracle Integration and migrate project and baseline data.
- Create an Integration User Account: You can create a Primavera Cloud integration user account to connect with Oracle Integration and manage integrations. Specify the integration account email address in the integration properties to receive integration notifications. Creating an integration account is optional but recommended to keep track of the data modified through integrations and to avoid issues related to using a standard user account, such as account lockouts or the employee leaving the organization. For more information, see Setting up an Integration User Account.
- Create Source and Target Workspaces: Workspaces represent the hierarchical structure of your organization's businesses, projects, or processes. Create the source workspace from where you want to export the project data and the target workspace where you want to import the data and obtain the source and target workspace IDs to specify in the integration properties. For more information, see Add a Workspace.
- Create a Project: Create the project (and baselines) to migrate the data and obtain the project ID. For more information, see Add a Project and Add a Baseline.
