4 Run the Recipe
After you have configured the connections, activated the integration, and updated the integration properties, you can run the recipe.
- Run the recipe.
- Monitor the running of the integration
flow in Oracle Integration.
- In the project workspace, click Observe. You'll see the integration flow being triggered and running successfully.
- To manage errors in your project, see Manage Errors in a Project.
- Log in to your Oracle Primavera Cloud instance to verify the project data was successfully migrated.
