Basic Info Page
You can enter a name and description on the Basic Info page of each adapter in your integration.
Element | Description |
What do you want to call your endpoint? |
Provide a meaningful name so that others can understand the responsibilities of this connection. You can include English alphabetic characters, numbers, underscores, and hyphens in the name. You can't include the following characters:
What does this endpoint do? |
Enter an optional description of the connection’s responsibilities. For example:
Select an operation name | Select an operation for the adapter. |
What is the endpoint's relative resource URI? | Displays the endpoint's relative resource URI. |
Request Object | Displays the request object based on your selected operation to send a request object to invoke. |
Response Object | Displays the response object based on your selected operation to get the response object from P6 EPPM. |
