3 Add the Primavera Unifier Adapter Connection to an Integration
When you select and place the Primavera Unifier Adapter into the trigger or invoke area of an integration, the Adapter Endpoint Configuration Wizard is invoked. This wizard guides you through configuration of the Unifier Adapter endpoint properties.
The following wizard pages that guide you through configuration of the Unifier Adapter as an invoke in an integration.
