Basic Info Page
You can enter a name and description on the Basic Info page of each adapter in your integration.
| Element | Description |
What do you want to call your endpoint? |
Provide a meaningful name so that others can understand the responsibilities of this connection. You can include English alphabetic characters, numbers, underscores, and hyphens in the name. You can't include the following characters:
What does this endpoint do? |
Enter an optional description of the connection’s responsibilities. For example:
| Select Level | Select the level within Unifier where you want to execute the service. You can select Company or Shell. |
| What action do you want to perform on the
endpoint? Note: This field is only available for the Invoke BP Selection page. |
Select the HTTP action you want to perform. Select GET to retrieve an existing record, POST to create a new record, and PUT to update an existing record. |
