4 Run the Sync Aconex Issues with Unifier Integration
After you have activated the integration and updated the integration property values, you can run the integration.
Synchronization Results
Running the Sync Aconex Issues with Unifier integration makes the following changes in Oracle Aconex and Unifier:
In Oracle Aconex:
- The Send to Unifier Issue field is set to Sent.
- The Unifier Project Number field is auto-populated.
- The Unifier Issue Record Number field is auto-populated.
In Unifier:
- A new issue is created or an existing issue is updated (if the issue status is not Closed).
- The issue description is updated.
- The first user-defined field, Issues Text 255 UDF 1, is auto-populated with the Oracle Aconex project ID.
- The second user-defined field, Issues Text 255 UDF 2, is auto-populated with the Oracle Aconex issue record number.
When the issue is created in Unifier, you can manually process and close it using the Unifier workflow.
You can also update an existing Oracle Aconex issue in Unifier (if the issue status is not Closed in Unifier) by changing the Send to Unifier Issue field to Yes and running the integration again.
